F1 2022 - GP Nº 19 : ESTADOS UNIDOS DE AMÉRICA - USA
Iniciado por McHouserphy, Oct 16, 2022, 02:56 PM
Albert Fabrega @AlbertFabrega · 19h
Alpine añade un corte con un generador de vórtices antes de la rueda trasera, como ya hicieran otros equipos.
Alpine adds a slot with a vortex generator ahead of the rear tyre, like other teams.
Los cortes de la zona central se han reforzado con más metal.
The central area with slots has been reinforced with more metal.
#f1 #usagp
Craig Scarborough @ScarbsTech · 4h
Interesting interpretation of the wing auxiliary component rules by Mercedes for the #USGP.
Teams are allowed upto 8 brackets to keep the slots between the profiles constant. Merc now use the full 8 & legally exploit them for an aerodynamic.
#F1 #TechTalk #COTA #AustinGP
The rules define the size and number to the slot gap brackets. Before these were half moon carbon pieces, with just 3 across the last slot gap & 3 on the first gap.
Additionally you're allow up to three crackers to allow the wing to pivot for adjustment.
#F1 #TechTalk #AustinGP
Mercedes now have the full 8 slot gap brackets, using 5 on the last gap and having them shapes like fins
While still acting as the supports for the slot gap. They no doubt have an aero function. Probably by turning the airflow outwards around the front tyre, called outwash.
Their size, shape and aero function appear to be within the rules.
Y sobre esos apuntes de Scarbs...
Timoteo Briet - Maths, CFD, Aero, Astro, Economy @TimoteoBriet · 1h
What is the purpose of those turbulators or vortex generators? they make more sense at the bottom, not at the top; perhaps the target is located further back. @AeroGandalf  @NaturalParadigm
josh @AeroGandalf · 1h
En respuesta a @TimoteoBriet y @NaturalParadigm
I assume create some bulk outwash in the flow. Position seems driven by rules about slot separators but not sure how they've got so many.
Vettel se ha vuelto jardinero.
Phillip Horton @PHortonF1 · 1h
COTA is planting 296 trees to honour Sebastian Vettel (number of race starts up to #USGP) – it will be called the Vettel Grove. First 20 being planted on COTA's campus, remainder will be in a grove nearby to help with floodplain restoration. #F1
La confirmación del mogollón de pilotos que va a participar hoy.
Se supone que esto es lo que han ganado/perdido los equipos desde el inicio de la temporada.
Mal regreso el de Giovinazzi. Se ha ido contra las barreras y ha provocado bandera roja, aunque la final ha logrado desengancharse y va camino a boxes.
Parece que el nuevo alerón delantero de Mercedes no va a rodar mucho.
Tobi Grüner 🏁 @tgruener · 2min
I'm hearing Mercedes brought only one version of the new front wing to Austin. With the tyre test in FP2 there is not enough time in FP1 for a back-to-back comparison run. So the new wing probably won't be used at all this weekend.
#AMuS #F1 #USGP
Brad Pitt en el garaje de McLaren pillando apuntes para su peli de F1.
Qué penica. DEP.
Chris Medland @ChrisMedlandF1 · 12min
Haas running a tribute to team member Harvey Cook who lost his battle with cancer yesterday at the age of 31. Had been a garage technician then moved to race track support in a factory role as he fought his illness #F1 #USGP
También lo han recordado en la pizarra.
Los logros del tercer español que hay hoy en pista.
